Any Recommendations for a Tripod?
Discussion in 'Equipment & Media' started by Stan Hesketh, Aug 16, 2019.
  1. Stan Hesketh
    Stan Hesketh Member
    Probably asked a lot, but my needs are quite specific and I would welcome any thoughts:
    I don't use a tripod a lot so don't want to spend a fortune.
    I don't have much room as I live on a boat, so need one that folds up small.
    Doesn't need to be all singing and dancing as will be used for landscape shots only.
    Still camera work only.
    Edit: I had £200 in mind.
    Many thanks.
  2. Pete Askew
    Pete Askew Admin
  3. Stan Hesketh
    Stan Hesketh Member
    Thanks that is the sort of thing I had in mind. I should have said around £200, now edited. Indestructible sounds good as I fall over a lot!
  4. Brian Moore
    Brian Moore Moderator
    Do you plan on taking the tripod down with you...? :rolleyes:
    Stan Hesketh likes this.
  5. Pete Askew
    Pete Askew Admin
    Mind, you might not survive if the Gitzo falls on you!
  6. Stan Hesketh
    Stan Hesketh Member
    LOL. That would not be good!
