Peri Trigkas
Active Member
grrr its EYETRACKER!!
I don't know if this one fits here or anywhere else in the forum but... I 'll ask!!
We have an eyetracker, which does what it says ...tracks the eye
It uses an infrared camera and the company has provided it with a Canon Lens 135mm.
I have 2 questions!
1. There are some vibration in the room we have the cam (it's mounted on a tripod). We ve been suggested to place the cam closer to the object to reduce the error.. The minimum distance of the lens is something like a meter (not sure I can check though). If we bring the camera closer using a 18-55mm lens for instance, the jumps caused by the vibrations will show smaller? I mean in absolute units. I dont know if I explain it correct.
I'll try to explain in another way just in case. Say u have the cam in 1m distance and focus on the eye with a 135mm lens. Everytime a vibration occurs the cam moves , say10mm from the focused point. If I use a 18-55mm and place the cam at 0.5m the error from the vibration will be again 10mm , smaller, or even bigger?
I know that the more you zoom the more difficult is to keep it steady. I am a bit confused though because in this case 2 parameters change. The focal length and the distance. Im sure that there is someone who is ..more than expert to explain it to me !!
2. Are all lenses suitable for infrared?
Whoever helps, gets credits in my thesis
Thanks in advance.
I have 2 questions!
Thanks in advance.
