Tom,...same temperatures as for B&W in other developers. ROughly 68-70 degrees f. I used the solution as a one-shot developer. I think it does not have much shelf life either once mixed. In practical terms, considering that your long term storage is in a very convenient powder form (coffee crystals, washing soda, Vitamin C), there seems little to be gained from mixing up more than you need at any given time.Excellent. Thank you everybody.
Couple of questions for Brian or Peter.
Any info on temperature. Water at room temp? Luke warm?
Can the used solution be recycled to use for a second film etc?
Yes you need to fix, Tom. Here's a link to a more comprehensive explanation of Caffenol. (@Dave Green may wish to look at this also.) Also, I believe I have the recipes I used jotted down. Pretty much they were adapted from some of those in the Caffenol Cookbook. I can post one or two up if you're interested.Thanks Brian. very helpful information.
One last point. Is there any fixing involved with this method, no mention of it on the link Dave gave me.
Thank you Brian. I'll have a good read of this Brian. Looks great. I would be very interested to see what you see as the simplest and most effective that you have used. I appreciate your help and advice very much.Yes you need to fix, Tom. Here's a link to a more comprehensive explanation of Caffenol. (@Dave Green may wish to look at this also.) Also, I believe I have the recipes I used jotted down. Pretty much they were adapted from some of those in the Caffenol Cookbook. I can post one or two up if you're interested.
http://www.caffenol-cookbook.com/index.php
