Hi Lesley,
This is how I would approach this type of shot:
Light paint the mine, use any powerful torch, Cree ones work well, but traditional bulbs can have a nicer warm tone.
When you are happy with your light paint shot, change the camera settings if required ready for the star trail.
I always use 30 second exposures stacked in startrails.exe. This means light pollution is not a problem. It also means you can have more than one attempt at the light paint part.
Star trail settings I use are F4-5, 30 second exposure, on continuous shooting, ISO 800 (You get the fainter stars).
For the light paint part, you can use lower ISO, just remember to put it back to 800 before the trail part.
Allow it to run for at least 30 minutes, but an hour or more looks better.
When you get home, choose the light paint shot you want to use. Use Photoshop to black out the whole sky (Then the stars won’t show up out of place in the trail.
Next put the black sky light paint shot, and all the star trail 30 sec exposure shots into startrails.exe. It will spit out your finished shot!
Sometimes it’s best to open the finished shot in Photoshop and increase the contrast a little. This blacks the sky, and brightens the stars.
Also another tip... When shooting the 30 second trail shots, set your camera to jpg, or at least RAW + Jpeg. Startrails.exe won’t take RAW files, so if you don’t do this you would have to convert them all from RAW to Jpeg first!
This stacking method means you can try all kinds of light painting on the mine. Plain white, or coloured gels over torches and flashes, you in your own shot, wire wool spins, anything realy.All safe in the knowledge that the trail part of the shot can’t be ruined by a fluff up on the light painting part!
Good luck with it, hope it turns out well!
Cheers,
Andy.
