It looks like I will be (hopefully) moving into my new apartment at the beginning of next month, its a nice 2 bed place with 2 large 'cupboards'. One of them contains the boiler and an electrical panel, however the other is an airing cupboard with shelves quite high up.
The airing cupboard also has a nice compact radiator but its actually got quite a bit of internal space and so I can easily get into it and close the door behind me with space enough for a small desk/table. As far as I can tell there is no electricity points in there or indeed any running water.
I am however thinking of converting this airing cupboard into a mini darkroom, but I would need some help on what I should go with. Here is my idea (need opinions if it would work).
How does that plan sound? I don't think I could fit anything like an enlarger in there due to the space that needs plus the need for power (which I guess I could temporarily run under the door).
The main thing I am looking into is how to make it light tight, are there special rubber seals etc that would seal light out from around the door?
I will post some before and after photos when I get the property and the progress I make, I just need to develop the negatives (black and white) rather than analogue enlargement as I will simply scan them in.
- Small table large enough to have a set of trays/dev. tank
- Light seals under the door to block out any light
- Red safelight (battery powered)
- Small tank of water for the wash phase - perhaps something like a brewing tank with a tap at the bottom to gravity feed
- Tank under the table to put in spent developer
- Small shelves under the table for chemicals (stop bath etc)
