Paul Lange
Moderator
I thought I already posted this but it has disappeared - Spooky
Wandering around Bury St Edmunds on Saturday I came across some stainless steel bowls in Thing Me Bobs - the local thrift shop chain. I had an idea of the DIY kind..................................
Took about an hour to make and was fairly straight forward. All I have to do now is cut some frosted polyprop sheeting into a circle so it can be used as a clip on diffuser. I had some of the bits at home anyway and luckily own a decent selection of tools. Well happy with the results so far. These were just taken while Kerri was on the sofa, no prep other than to raise the stand so it was pointing down on her. Kerri likes them which is good as it means I should be able to convince her to pose properly soon so I can have a proper go a really get to grips with using it.
