Adam Lewis
Hi everyone,
I'm after a bit of advice.. I've seen hundreds of lenses on fleabay with fungus and dust inside going for cheap, so I took a dip and bought one for £12, bought some lens cleaner, a brush and a precision screwdriver set.
Idea perhaps being- sort out the lens & resale (though ill probably end up keeping it
However I'm having an issue with the said lens. The back plate screws seem smaller than the 1mm screwdriver bit. Meaning I can't unscrew them? I've looked around online and I can't find a smaller screwdriver?
Is there smaller ones used in production? Or do you suspect my 1mm screwdriver is actually bigger than 1mm? (It is a cheap set)
Thanks
Thanks
