Thanks Geoff, it would be interesting to see how you did it. With mine I was pushing my luck a little with a 30s exposure @24mm. Apart from anything else, looking at the original at 100% the individual points of light are somewhat stretched into short lozenges. Luckily the overall effect isn’t too marred by it.
I do quite like nocturnal landscape approach and there are certainly some fantastic images to be seen online. As for more serious astrophotography, I think my missus might notice the missing hundred grand lol.
These are the notes. It misses out the production of tiff files in Stacker, its these files that are loaded as lights, flats etc. Good luck!
Before photographing:
1. Shoot a flat frame
2. On the night and once the camera has acclimatised take dark frames
RawTherapee
1. Raw Tab
a. LMMSE 2 enhancement steps (high ISO) or AmaZE
b. click hot and dead pixel filter, ClarkVision uses 143 for Threshold
c. Load dark and flats (only one of each allowed)
2. Transform Tab – all at defaults (auto lens correction)
3. Advanced – none
4. Colour Tab
a. Daylight colour
b. Colour management (last tab) – ClarkVision uses Rec 2020 for working and output (RTv4_Rec2020 used)
5. Detail and Noise reduction
a) Noise reduction – RGB colour space, luminance control Curve (and default settings); Chrominance – Manual and default settings
b) Defringe turned on (default settings)
6. Exposure Settings
a) Clip turned off; highlight reconstruction – colour propagation; exp comp – minus 0.66 to 0.75, increase (?) black point if image is dark to ensure no clipping; tone curve – standard; other settings at default
Copy settings (top right “save profile”) to disk (permanent save)
Apply to other images in the set – file browser, ctrl-c to copy setting to clipboard; select all the other images to apply the settings to and ctrl-v; select all images that the setting should be applied to [including original] and right click one, select send to queue; then click Queue tab, choose output directory and 16 file output and start processing.
