Some people may have noticed a discussion between my self and Shifty Pete in the thread about the "Thumbs Up" thumb rest for the x100
http://www.realphotographersforum.com/threads/2107-Thumbs-Up-for-the-Fuji-X100
I shall quote Petes description of what they are for
Well I subsequently bought one from ebay for £4.90
http://www.ebay.co.uk/itm/mini-Soft...ultDomain_3&hash=item230cf1e6f5#ht_970wt_1139
I have had a few days use with it now, I have tried it on my voigtlander vito b, R2A and now the fuji x100 so thought i would share my thoughts.
I can definitely confirm that they do fulfill exactly what Pete described.
Because the tip of your finger rests on the camera on the opposite side of your grip and you push down with your joint, the required pressure appears less.
The upshot of this is that the camera remains much steadier when the shot is fired ...
Holding the camera in one hand and watching the camera as i push the button it is actually visibly more stable!
I would definitely recommend one of these to anyone who has a camera with threaded shutter botton
The soft-release raises the actuating position of the shutter release making it easier to trigger as you're not pressing 'into' the housing (if you get my meaning). This means that you can either use the new, larger surface (not much advantage) or you can rest the tip of your forefinger on the shutter speed control dial (I'm obviously talking Leica M and other 'traditional' cameras - I assume the ergonomics would be similar on the X100) and operate the shutter release using the pad between the first and second joint of your finger by gently straightening out your finger. So the action becomes less of a press and more of a squeeze (as in classic rifle shooting technique) - I know you can / should do this anyway but the soft-release makes it easier and means you finger is always on the the shutter speed dial (useful if you are shooting manual or in aperture-priority mode - there is no other option on a Leica). I was skeptical of this and have tried both the Beep, Bip and the Boop (well, they have to called something I suppose) and they do indeed work. Although the Beep is probably better suited to the technique, I preferred the Boop. The only down-side of these devices is that it is very easy to trip the release accidentally while carrying the camera.
