Whilst looking into dark glass (ND Filters) - I came across a number of examples of metering anomalies with the X-Pro1, that suggested to me that this camera was seeing infra red light, as well as visible light.
This would be an exciting revelation, a camera that does IR out of the box, without requiring permanent internal filter modifications would be an great tool for a whole new field of photography.
One quick way to find to - buy an IR filter, and try it out.
Well, today my Hoya R72 filter arrived - a rather specialist filter designed to block visible light, and allow IR wavelengths above 720 nm to pass through to the sensor.
In practice, The R72 hits 50% transmissivity at 720 nm, just inside the Near Infra Red (NIR)
I screwed it on - set ISO at 400 and the aperture at f8 for some DOF - and put the X-Pro1 on a sturdy tripod.
IR exposures can be long - there's not much illumination getting through even on a sunny day like today!
Here are the initial test shots from the front patio:
Success!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You can see that plant-life goes white - so leaves etc glow in a nice ethereal way - Skies have super contrast, as if you used a CPL.
Focus seemed to be a non issue for the X-Pro1, as the camera was focussing using the contrast in the image - so issues with different focal lengths for the different wavelength of light do not seem to matter using this system.
The original files are deep brick red in color - I'm going to see if I can set a custom WB setting to give me false color IR shots from the camera - as well as the processed B&W shown here.
Very exciting stuff - and the good news is the Hoya filters are not expensive.
Success!
