New X-Pro1 firmware released - X-Pro1 Firmware Update Ver.1.10
Firmware for X-Pro1 | Fujifilm Global
Adds functionality for the new M Mount adapter
1.New function for "FUJIFILM M mount adapter" is added to the shooting menu.
2.The MENU name "FOCAL LENGTH SETTING" is changed into "MOUNT ADAPTER SETTING", and new correction menu is added.
DISTORTION CORRECTION,
COLOR SHADING CORRECTION
PERIPHERAL ILLUMINATION CORRECTION
3.Even if "LENS 5" or "LENS 6" (adjustable focal length) is set, the Bright Frame can be displayed on OVF in accordance with focal length.
(Recommended lens focal length for OVF to check the Bright Frame: from 18mm to 60mm)
4.In MF (manual focus) mode, sharpness of live image at 10x magnified operation (by pressing the command dial) is set to high and focusing point can be much easily confirmed.
5.When FUJIFILM M mount adapter is connected to the camera body, the following issues are effective.
(1)By pressing the function button of M mount adapter", "MOUNT ADAPTER SETTING" menu is displayed quickly.
(2)"SHOOT WITHOUT LENS" is automatically set to "ON"
(3)"Distance indicator (Manual focus indicator)" in "Standard display" mode on EVF/OVF is automatically set to "OFF"
(4)3 types of correction menu (DISTORTION / COLOR SHADING / PERIPHERAL ILLUMINATION) are activated.
