Large Format, Paper Negative, DIY Camera Project
Although the Mk II screen was much brighter than the Mk I, it was not possible to use a loupe so I made the Mk III. Again based on a piece of glass from a clip frame, the screen was made using a second sheet of glass and grinding paste. I used oil-based, medium-grade, valve grinding paste (as that was all that was to hand) but fine would have been slightly better. I added water and washing-up liquid to form a thinner emulsion and it only took about 10 minutes of grinding by hand to get a uniformly matte screen. Focus is much, much easier and is now accurate as can be seen in this test print (ca 6 seconds exposure) - the focus point was the larger seed pod in the bowl.
I stripped the print dryer down and cleaned it and re-shot the image. This time I scanned at 600 ppi (rather than 300) and inverted the image in PS.
Below is a detail from the area of focus.
I have just modified the base of the camera to improve its stability when mounted on a tripod. I originally intended to screw a sheet of ply into the recess below the camera but then realised this would cause problems with the fitment of the lens box. So instead I have added a second layer of plastic around the tripod boss and reinforced the front section and an area towards the back.
This shows the internal bracing of the rear reinforcement.
And this is the completed modification with the plate of a large ball and socket head mounted to the tripod boss.
It is not perfect but certainly more rigid and should give the extra stability I was after.
