There is a Kodak shop in Edinburgh, processing 35mm film, 1-hour services, etc, the usual. I dropped them an email asking if they processed 120 film, and to my surprise the answer was "Yes, as long as it's C41". I have some, as yet unused, Portra 400 which is indeed C41, but some my other rolls don't say.
So, I'm wondering what all these letters and numbers refer to, and why some developers only do C41, while others charge extra for it?
And is C41 better or worse in certain characteristics than others?
Unless you are experimenting with bizarre colour, C41 and colour negative films were designed to work together. Chromogenic films—such as XP2 as mentioned use C41—as well. There is no alternative. Companies other than Kodak did make chemistry for colour negative processing, but it still was C41. I did experiment with pushing C41 at one time and there were non-linear shifts in colour layers that made accurate colour balance impossible. The term is "cross-over", which can result in yellow shadows and blue highlights. Correct for one and exacerbate the other.
XP-1 which I used in the day, and now XP-2 have very long dynamic ranges—high latitude. There was no point in trying push/pull processing, since they variations in exposure were dealt with in printing. Depending upon the shoot, I found them useful from ISO50 to beyond ISO800. Contrast varied with exposure, so variable contrast paper was absolutely required to get the best results. It was very different from silver halide emulsions to print, and a lot of shooters gave up in a rage when it was first introduced. Generally, the best results came with higher contrast paper and loads of dodging and burning to take advantage of local contrast.
Chromes are strictly E6, now that Kodachrome is history. Processing any colour film is an exact process. Temperatures are precise to within a fraction of a degree, and time in each solution is also absolute. While you can process colour film at home, the closer you can come to emulating a machine the better will be the results. I kept film chemistry in my lab, but only used it when faced with an overnight deadline, even though I had high accuracy temperature controls and timing.
There is cross-processing, mostly E6 film in C41. Results are highly unpredictable, and there was a short period in the 1970s where fashion photographers did experiment with it. It quickly became a cliché and vanished from sight.
Standard B&W is a totally different beast. There are fine-grain, high-energy, high-acutance, etc. developers that give subtly different results depending upon your goal. Vary time and temperature, again for different results. It was—and still might be—possible to buy the ingredients and mix your own, or alter over-the-counter chemistry. This was popular among those who were process oriented—the equivalent of pixel peepers today. No interest in photography, but hopping onto every trend that came down the line. Results were wildly unpredictable. Working photographers who needed predictability for earning their livelihood generally picked a single developer that would work with two or three films, and established routines that produced totally consistent results.
